VB Help: Fix "Conversion from string to type 'Double' is not valid" Error
  • Thread starter Thread starter youngsc
    Visual
The discussion revolves around a programming issue in Visual Basic 2008 related to converting string inputs from text boxes into double values for arithmetic operations. The initial error encountered was due to attempting to assign an empty string to a variable defined as a Double, resulting in a conversion error. The user later attempted to convert text box values to Double using the CDbl function but faced issues when trying to divide these values, receiving an error indicating that the operator '/' was not defined for text box types. The solution highlighted was to ensure that arithmetic operations are performed on numeric values rather than strings or UI elements. Ultimately, the user resolved their issues by switching to C#, where they found more accessible examples and resources. The discussion emphasizes the importance of proper type conversion in programming and the challenges faced when learning a new language.
youngsc
Ok I'm just starting to teach myself and I thought I could have at least gotten this part but I'm getting a Conversion from string "" to type 'Double' is not valid. error message.
Code:
Private Sub StockPricetxt_TextChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles StockPricetxt.TextChanged
        Dim StockPricetxt As Double
        StockPricetxt = ""
    End Sub
What's happening when I test it is the second you put anything in the text box it freezes and return the error message above. The larger code will be to take this value and another and divide them. I'm assuming it has to do with the use of double but I'm lost. I would appreciate any help you all could give me. Using VB 2008 btw.
Also, great forum I've been surfing it for a little while now and it's a lot of good info to be had.
Technology news on Phys.org
Ok that problem is solved now I got a new one.
Code:
        StockPricetxt = CDbl(StockPricetxt)
    End Sub
    Private Sub EPStxt_TextChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles EPStxt.TextChanged
        Dim EPStxt As Double
        EPStxt = CDbl(EPStxt)
    End Sub
    [B]Private Sub PEtxt_TextChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles PEtxt.TextChanged
        Dim PEtxt As Double
        PEtxt = StockPricetxt / EPStxt[/B]
    End Sub
I'm trying to divide these values and the last sub bolded I'm having trouble with. It's telling me "Operator '/' is not defined for types 'System.Windows.Forms.TextBox'". Any ideas? I am searching this stuff on the web and can't come up with exact results to give me what I need.
TIA
Are you attempting to do arithmetic on text? (i.e. a string?).
Convert the text to a double before attempting the divide.
Thanks for the reply. I got it figured out, I used C# instead. I'm trying to teach myself quite a bit of this and I'm doing as much of it "example" based as possible. I couldn't find any good examples in VB but found a lot in C#. Thanks again.
C# is better than Visual Basic, to be sure. Just be sure to do math on numbers, not strings or UI elements.
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
Thread 'Project Documentation'
Trying to package up a small bank account manager project that I have been tempering on for a while. One that is certainly worth something to me. Although I have created methods to whip up quick documents with all fields and properties. I would like something better to reference in order to express the mechanical functions. It is unclear to me about any standardized format for code documentation that exists. I have tried object orientated diagrams with shapes to try and express the...
