Solving an Infinite Series: 1/2(2/3)^n
Wholewheat458
I am to find the sum of the series, but what do i do if it is infinite?? no clue.
i'm also not sure how to type the symbols so i hope you can understand me:shy:
: (Sum) n=0, limit = infinity: 1/2(2/3)^n
i 'm not sure.
i understand how to add up to a limit, but what do i do with the infinity?
Well if the 1/2 is the first term in the product then you can pull it out front (this is obvious by the distributive law). Then recognize it as a geometric series. There is a simple formula for an infinite geometric series which you should try deriving yourself.
.. 1/2(sum)n=0, infinity (2/3)^n+1 ..
?? do you just leave it like that?..
as a sort of equation?
Ok an infinite geometric series like a normal one has a first term conventionally detonated as a and common ratio r. Since we start at n = 0, the first term is (2/3)^0 = 1 (You can't just change the exponent from n to n+1 unless you change the starting value. Making do with what you're given is best in this case). Then we go to n = 1, the second term is (2/3)^1 = 1*(2/3) = 2/3. Then for n = 2, the third term is (2/3)^2 = (2/3)(2/3). Now the idea is to sum all of these terms, i.e. 1 + 1*(2/3) + 1*(2/3)*(2/3) + 1*(2/3)(2/3)(2/3) + ...
So we can generalize a bit. We have a as our first term and a common ratio r. Our sum, which we'll denote S is
S = a + ar + ar^2 + ar^3 + ... (1)
(Compare with the first paragraph to understand why this is true).
Now we need to solve for S because that gives us the sum. The trick here is to multiply S by our common ratio r, i.e. multiply both sides of (1) above by r and write it underneath. Then subtract the new equation from (1) and see for yourself how all the terms cancel and allow you to solve easily for S
i 'm not sure.
Hi Wholewheat458! :smile:
\sum_{n=0}^{\infty} \frac{1}{2}\,\left(\frac{2}{3}\right)^n
=\ \frac{1}{2}\,\sum_{n=0}^{\infty} \left(\frac{2}{3}\right)^n
You should know what \sum_{n=0}^{\infty} \left(\frac{2}{3}\right)^n is,
but if you don't, just sum it from 0 to N, and then let N --> ∞ :smile:
(btw, it's [noparse]\sum_{n=0}^{\infty} \frac{1}{2}\,\left(\frac{2}{3}\right)^n[/noparse] :wink:)
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
