I need to use the given equations to derive the equation for final velocity.
To derive the equation V2x² = V1x² + 2axΔt, the key is to eliminate the variable Δt from the given equations V2x = V1x + axΔt and ΔX = V1xΔt + 1/2axΔt². The discussion emphasizes the need to correctly identify which variable to eliminate to achieve the desired result. Additionally, there is a note that the initial statement of the final equation contains an error. The focus is on applying algebraic manipulation to arrive at the correct equation.
rdubs
Given the equations V2x= V1x+ax\Deltat and \DeltaX= V1x\Deltat+ 1/2ax\Deltat2, i need to derive the equation V2x2=V1x2+2ax\Deltat. please help me!
Welcome to PF.
What variable do you need to eliminate from the equations you are given to get the answer? (Btw, your statement of the final equation is in error.)
Armed with that ... it's Nike time ... just do it.
