How to Solve a Long Jumper's Kinematics Problem?
  • Thread starter Thread starter kmikias
    Kinematics
A long jumper takes off at a 20-degree angle and reaches a maximum height of 0.55 meters. The time in the air is calculated to be 0.67 seconds using the formula for vertical motion. To find the forward component of her velocity, the vertical and horizontal components of the initial velocity must be considered, using the sine and cosine of the angle. The horizontal distance can be determined by multiplying the horizontal velocity by the total time in the air. Understanding the relationship between the angle and the components of velocity is crucial for solving the problem.
kmikias
Hi ...I came up another question again i guess you will help me out .Here is the question
1. A long jumper takes off at an angle of 20 degree with the horizontal and reaches a maximum height of 0.55 m at mid-flight.
- how long is she in the air?
- what is the forward component of her velocity?
- how far does she jump?
Here is what i try.
A. how long is she in the air.
i use the formula Y= vt + 1/2gt^2
which is -0.55 = 1/2 * -9.8 t^
so t= 0.335 sec and finaly i multiplay 0.335 * 2 = 0.67 sec.
B. here is where i stop how can i find her velocity without knowing the horizontal distance.
i know the formula X = vt
thank you.
Here is what i try.
thank you.
Think about what the horizontal and vertical components are of her initial velocity.
(Hint: They give you an angle.)
Horizontal velocity has nothing to slow it so you are right that distance will be Vx * t.
Vertical distance is given so you know the total time from doubling how long it would take for her to fall. And that you know as = 1/2 g*t2
yes i did but i still didn't get that because how can i find with only one given angle
That's how you solve the problem.
Vy = V*Sinθ is the Y component of the initial velocity.
Vx = V*Cosθ is the horizontal component.
