What is the time taken for these 2 cars to meet?
  • Thread starter Thread starter nyrychvantel
    Cars Time
Two cars, P and Q, start 1400 meters apart, with P traveling at a constant speed of 15 m/s and Q accelerating from rest at 5 m/s². To find the time taken for them to meet, one can set up equations for their positions over time and equate them. Car P's position is given by S = vt, while Car Q's position can be calculated using S = ut + 0.5at², with adjustments for direction. The discussion emphasizes the importance of using kinematic equations rather than graphical methods to solve the problem efficiently. The solution involves calculating the distance each car travels before they meet.
nyrychvantel
Two cars, P and Q, are 1400m apart.
P is traveling at 15 ms-1, Q is accelerating from rest at 5.0 ms-2
They are traveling opposite direction(i.e. they are facing each other), what is the time taken for them to meet?
Also, what is the distance traveled by each car before meeting each other?
a = \frac{v-u}{t}
I got a = 5t, but it did not seem to help much...
Do I have to draw a graph for this question?
a = \frac{v-u}{t}
No, just write out the position dependence over time for the two cars and equate. Assume Car 1 to b at x=0 and the second car to be at x=1400
Use
S=u*t+0.5*a*t*t (for the accelerated motion) (Use negative sign for acceleration)
S=v*t (for the constant velocity motion)
Thank you!
I forgot I can use area under a V-T graph of constant acceleration (and sub v=at) to get the total distance traveled by car Q.
