Rotational Motion (should be easy-need quick tip)
A car accelerates around a circular track with a radius of 30 m and a constant tangential acceleration of 0.5 m/s². To find the net acceleration after 15 seconds, the centripetal acceleration is calculated using the car's velocity derived from the tangential acceleration. The discussion clarifies that angular acceleration is distinct from net acceleration, emphasizing the need to determine the angle between tangential and resultant acceleration for part B. Participants share resources to aid understanding of rotational motion concepts. The conversation concludes with the user feeling more confident about solving the problem.
mistymoon_38
A car starts from rest and moves around a circular, horizontal, level track of radius 30 m. Its speed increases at the constant rate of 0.5 m/s^2. (a) What is the magnitude of the net acceleration 15 s later? (b) What angle does the net acceleration make with the car's velocity at this time?
I think I got part A. I just found the vector sum of of the centripetal accleration, V^2/R (found V by taking integral of 0.5 from 0-15s), and the given tangental accereration of 0.5.
Does this sound right?
As for part B I have no idea. I don't think I can use constant acceleration kinematic equations...
Also- is there a difference between the angular acceleration and the net acceleration?
For B you know the components of the acceleration. All you need to do is find the angle between the tangential acceleration and the resultant or net acceleration.
Yes angular acceleration is different to the net acceleration. This page may be of use to you.
http://hyperphysics.phy-astr.gsu.edu/HBASE/rotq.html#drot
thanks i think i got it now.
