Amperage ratings on DC power supplies
A user is seeking advice on using a 1.25 A DC power supply for a router that originally requires 1.0 A, after the original power supply failed. The user believes the router won't draw more than 1.0 A and is concerned about potentially damaging the router with the new supply. Responses indicate that a 1.25 A supply is safe and may even operate cooler, but caution is advised regarding the router's condition. There is a suggestion to measure the power supply's output when disconnected from the router to rule out any issues with the router itself. Overall, using the higher-rated power supply is deemed acceptable, but further investigation into the router's functionality is recommended.
KLoux
Hello,
I'm hoping that by asking this question I can save myself a couple of bucks. I have a DC power supply for a router that is rated for 1.0 A. My router stopped working, and I traced the problem to the power supply. It's a 12 V supply putting out 0.1 V. I have other 12 V supplies, but the closet I can get on the amperage is 1.25 A. My thinking is that the router probably won't draw more than 1.0 A anyway, so a 1.25 A power supply would still be OK. Is this safe? Is there anything else that I'm not considering (what ifs?) What I don't want to do is fry the router and have to spend $70 instead of ~$10 for a new power supply.
Thanks,
Kerry
What is your router specs? If it draws 1 amp then that is probably why the power supply got fried. With a 1.25 amp rateing, you're good to go. With the extra rateing, the supply will run cooler.
It was the power supply that came with the router, and the router has 12V, 1.0A printed on it, too.
Thanks for the help, I'll give it a shot!
-Kerry
did you measure the supply unconnected to the router?
If not your router may have some problem, this seems like a loading issue.
So another supply won't help.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
