Partial Differentiation of an expression.
shadap
Find the partial of z with respect to x keeping r constant.
z=x2+y2
x= rcos(t)
y= rsin(t)
= r^2(cos(t))^2 + r^2(sin(t))^2
use product rule on "x" and hold r and y constant
= [0(cos(t))^2 + r^2(2cos(t))(-sin(t)))] + 0
simplify terms
= -2r^2(cos(t)sin(t))
I am confused because to hold r constant, does that mean i hold both r and y constant?
thanks
z=x2+y2
x= r cos(t)
y= r sin(t)
simplify terms
thanks
You're given z as a function of x and y, and asked for \frac{\partial z}{\partial x}. The bit about holding r constant seems to be a red herring. To help you out a little, \frac{\partial z}{\partial y} = 2y.
BTW, I corrected the definitions of x and y per your later submission.
In this case we are holding x constant, but what is happening to r? How can i hold r constant if it is connected to theta? Do I hold theta constant as well?
It doesn't matter what happens with r and t (your original post gives t, not theta). You have three functions: one with z as a function of x and y, one with x as a function of r and t, and one with y as a function of r and t.
The question you asked was, what is \frac{\partial z}{\partial x}. As a hint, I showed you what \frac{\partial z}{\partial y} was.
You didn't ask, but there are other partial derivatives that could be gotten, namely \frac{\partial z}{\partial r} and \frac{\partial z}{\partial t}. As it turns out, both of these partials are zero. For each of these partials, you do have take r and t into consideration, which you do by using a form of the chain rule for partial derivatives.
For the functions you have in this problem,
\frac{\partial z}{\partial t} = \frac{\partial z}{\partial x} * \frac{\partial x}{\partial t} + \frac{\partial z}{\partial y}*\frac{\partial y}{\partial t}<br />
The chain rule form for \frac{\partial z}{\partial r} is similar, but involves \frac{\partial x}{\partial r} and \frac{\partial y}{\partial r}.
Mark
You didn't ask, but there are other partial derivatives that could be gotten, namely \frac{\partial z}{\partial r} and \frac{\partial z}{\partial t}. As it turns out, both of these partials are zero. For each of these partials, you do have to take r and t into consideration, which you do by using a form of the chain rule for partial derivatives.
The chain rule form for \frac{\partial z}{\partial r} is similar, but involves partials of x and y with respect to r, instead of with respect to t.
Mark
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
