Compton Scattering: X-ray 0.010nm, 180 Degrees
  • Thread starter Thread starter getcarter
    Ray
getcarter
3) X-rays of wavelentgh 0.010nm are directed onto a target containing loosely bound electrons. For Compton scattering from one of those electrons, at an angle of 180 degrees, what are
a) the Compton shift,
b) the corresponding change in photon energy,
c) the kinetic energy of the recoiling electron, and
d) the electron's direction of motion?
Lamda'-Lamda = [h/mc] (1-cos@)
\frac{h}{m_e c} = 2.43 \times 10^{-12}\,m
p_{e'}^2c^2 = (hf + mc^2-hf')^2-m^2c^4
in your equation, for scattering at 180 degrees, what is "cos@" equal to?
relevants are above, i did not understand that you ask cos@,
sorry i don't understand the main idea of the question
and i need help.
and i need help.
I am asking you this to determine whether or not you understand what the symbols in the equation are.
You wrote down something that says "cos@". Do you know what the symbol @ stands for?
i tried to show tetha, [degree of cos.]
sorry.
sorry.
Yes. And in the statement of the problem, what number is theta equal to?
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
