Can Euler's formula accurately calculate arcsine?
  • Thread starter Thread starter Marie Cury
    Euler Formula
Euler's formula for arctan is being used to calculate arcsine, but issues arise with accuracy at high decimal inputs, particularly with values like 0.9999999999 and 0.99. The discussion highlights that while lower inputs like 0.9 yield correct results, higher precision leads to significant errors. Participants suggest that the problem may stem from truncating the infinite series, which affects the accuracy of the results. One user reports achieving four correct digits with n=13 and ten correct digits with n=32, indicating that increasing n reduces error. The conversation emphasizes the importance of proper calculation methods and series truncation in achieving accurate results.
Marie Cury
1. I use Euler formula of arctan to calculate arcsine
2. This equation\arctan x = \frac{x}{1+x^2} \sum_{n=0}^\infty \prod_{k=1}^n \frac{2k x^2}{(2k+1)(1+x^2)}.
If I input 0.9999999999, I will not be able to get the expected result. If input = 0.9 then it is pretty correct, but 0.99 is definitely wrong and more wrong when the decimal digits get higher till uncomputable.
Could someone help me ? :wink:
2 weeks already and everyone stopped breathing into my thread!
you ignore my post I guess!
It sounds like you just need a better calculator, try using Mathematica.
It wasn't clear what you were asking. It's an infinite series, so you must be truncating it at some point, and so of course the result is not exact.
I don't see what the problem is, I get at least 4 digits correct If I evaluate the sum for n<=13 and 10 digits correct for n<=32. (I don't think n=0 should count).
Because \frac{2k x^2}{(2k+1)(1+x^2)} is smaller than 1/2 for all x, the error must halve for each increase of n.
I used the following python program
Code:
rom math import *
x = 0.9999
limit = 20
sum = 0
for n in range (1, limit):
    prod = 1
    for k in range (1, n):
        prod *= 2*k*x*x/((2*k+1)*(1+x*x))
    sum += prod
    print n, atan(x), sum * x / (1+x*x)
1 0.785348160897 0.4999999975
2 0.785348160897 0.666649995833
3 0.785348160897 0.733303328833
4 0.785348160897 0.761866186262
5 0.785348160897 0.77455952004
6 0.785348160897 0.780328640213
7 0.785348160897 0.782991044782
8 0.785348160897 0.784233375995
9 0.785348160897 0.784817943983
10 0.785348160897 0.785094816918
11 0.785348160897 0.785226647987
12 0.785348160897 0.785289691324
13 0.785348160897 0.785319949099
14 0.785348160897 0.7853345162
15 0.785348160897 0.785341547891
16 0.785348160897 0.785344949982
17 0.785348160897 0.785346599315
18 0.785348160897 0.78534740034
19 0.785348160897 0.785347789989
20 0.785348160897 0.785347979799
Converges nicely as you can see.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
