Sliding friction, position/velocity as a function of time?
Calculating the position and velocity of a particle with non-zero velocity and acceleration, while accounting for sliding friction, is indeed possible. The friction force, which opposes movement, can complicate the equations of motion but can be integrated into a continuous model. The challenge lies in defining the function f(dt) that represents the effects of friction over time, as it may vary based on the particle's changing velocity and direction. Kinetic friction is inherently piecewise due to its dependence on the direction of movement and the forces acting on the particle. A continuous physics simulator can incorporate these dynamics by carefully modeling the frictional force in relation to the applied forces.
mcevans
If this question is completely stupid, forgive me, I'm a few years out of university and math and physics are quickly leaving my brain... :)
Say a particle has a non zero velocity in one direction and a non zero acceleration in the opposite direction. If you also account for some sliding friction force opposing this movement, is it still possible to calculate its position and velocity as functions of time?
I've been googling around for a while and can't seem to come up with what I want. I'm trying to write a little (extremely simplified) continuous physics simulator, and after some timestep dt I need to be able to say "new_x_position = velocity * dt + f(dt)" where f is some mystery function- right now the only things I can come up with are piecewise functions.
edit: I should clarify- the source of my confusion is that sliding friction can never exceed whatever applied force is causing the particle's acceleration, and must always oppose movement, even if the particle's direction changes during that timestep
I guess this question could be summarised as, "Is kinetic friction inherently piecewise?"
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
