Saltwater voltage source question
The discussion revolves around creating a saltwater battery to power an LED, where the user achieved 4.75 volts but the LED only lights briefly before going out. Suggestions include increasing the number of cells, using different metals for electrodes, and enhancing the surface area of the electrodes. The brief illumination of the LED is attributed to the rapid discharge of ions in the electrolyte, similar to a capacitor's behavior. Concerns about the battery's performance when fully discharged are raised, emphasizing the need for a better understanding of electrolytes and current flow. Overall, the project highlights the challenges of using saltwater as a weak electrolyte in homemade batteries.
Lefteris
Hello all,
I am just a guy playing around. I was trying to see if I understood correctly what electrolytes were, so I set out to make a simple "battery" out of saltwater. It has been done before many times and I thought I could at least make it light an LED.
Here it is :
http://img262.imageshack.us/img262/9741/salt1mv8.jpg
http://img224.imageshack.us/img224/9440/salt2pl7.jpg
The problem is that despite the fact that I managed to reach 4.75Volts of voltage I can't make the LED light up.
To be precise , whenever I make contact and close the circuit it lights up for an instant and then the light dies out. If I repeat .. the same happens each time. That is the reason I am writting this topic too. I would like to ask anyone who might know why it does not function as I thought it would be? I am trying to understand physics just as a hobby so please go easy on me if I said something really stupid in this post. :)
Thanks in advance for any comments ,
-Lefteris
P.S. : Also another question, I read something about amperage but from wikipedia I deduced it is the same as current? Is that correct? Also ... unfortunately my internal fuse has been broken in the multimeter and I can't measure current :(
A few weeks ago we built cu/ lemon/zn cells in the classroom. We had to put more then 10 cells in series to generate enough current to ligth a led. Try more cells.
As for the missing fuse... do you have any solder or Al foil? Simply short out the fuse holder with a wrap of solder or a strip of foil. You will not be fused, but for this project it should be fine.
Hello!
Thanks for the reply. I am using exactly 10 cells. I will try to increase their number and see if it will then light the LED. Thanks. As for the fuse of course I have solder, just need a screwdriver to fit and remove the screws from the multimeter.
I have another question though. Since this whole thing is something I did to better comprehend what a battery is. I am now wondering. What happens when you totally discharge a battery? Say What happens when I discharge this batery tottaly? The electrodes won't work anymore , or the water-salt combination will need changing? Or both?
I suggest the led illuminates briefly then goes out, is because while you are drawing no current from your cell the cell electrolyte slowly builds up a good quantity of ions which discharge quickly and briefly. (a bit like discharging a capacitor). From my own home-made cells I have seen short current spikes of over 1 amp. If you put a sensitive ammeter across the cell, you would see the current spike. The current and voltage then settles down again, but not enough unfortunately. From my experience, you will need to massively increase the area of your electrodes. Sea water is a very weak electrolyte. Unlike commercial cells, the voltage drops extremely quickly as you draw current. Forget about theoretical voltages as per the electromotive series.
Increasing the number of cells will not necessarily work because it is in the nature of these lashups that one cell will be inefficient quicker, and the others will waste their output trying to equalise/recharge it thus bringing down the whole battery. Thw weak one will gas more vigorously.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
