Why Do Treadmill Calorie Counters Vary with Speed?
  • Thread starter Thread starter pushkarvaidya
    Count
Calorie counters on treadmills vary with speed due to the difference between mechanical work and the physiological demands on the body. Although walking the same distance involves the same mechanical work, increased speed elevates heart rate and breathing, leading to higher energy expenditure. The body requires more energy to maintain homeostasis at faster paces, which is not reflected in the simple distance measure. This additional energy expenditure accounts for the discrepancies in calorie readings. Understanding this distinction clarifies why treadmill calorie counters provide different values based on speed.
pushkarvaidya
I have a very basic question related to energy here.
We all know that calorie is a measure of energy.
Also Energy spent = work done (ignore efficiency)
When you walk 1 mile on a treadmill you are doing some amount of work. Based on the above equation you are using up some amount of energy. This energy is measured in calories.
Now suppose you walk the same distance, but in half the time, you are still doing the same amount of work (of walking 1 mile) so you are using the same amount of energy. The only difference is that you are doing it at a faster rate.
Why does the calorie counter on a treadmill give dramatically different values in both of the above cases.
Is the work done in both cases not the same? Should the calories burned not be the same?.
Please help me resolve this question.
Mechanical work is not the same as the chemical work your body has to do. While you are still going the same distance, think of how many more times during that mile that you breathe and your heart beats. Think of how much warmer your body becomes. All of that is the extra work you are not accounting for by simply looking at the mechanical work.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
