Doppler effect measure speed in blood cells
To calculate the frequency shift of ultrasound reflected from blood moving at 0.20 m/s, the Doppler effect equations are essential. The frequency of the ultrasound emitter is 5.0 MHz, and the speed of sound in the medium is approximately 340 m/s. The ratio of wavelengths relates to the speeds of the object and wave, allowing for the calculation of frequency shift. The discussion emphasizes the need for additional information to solve numerically for the wavelength if it is not provided. Understanding these principles is crucial for accurately measuring blood flow using Doppler ultrasound technology.
hellokitty
A Doppler blood flow unit emits ultrasound at 5.0 {\rm MHz}.
What is the frequency shift of the ultrasound reflected from blood moving in an artery at a speed of 0.20 m/s?
What equations would I use to calculate the doppler shift? It is not in my textbook...
I believe off hand that the ratio of wavelenghts is equal to the ratio of speeds of the object;
L = wavelenght
L0 = wavelenght before reflection
V = velocity of wave in medium
V0 = velocity of wave.
V0=fL0 where f is the frequency of the ultrasound emitter.
L / L0 = V / V0
I think that's all the infomation required for the solution. See if you can do it now. If not highlight the below;
L / L0 = 0.2 m/s / speed of sound ( 340 m/s) = Y
Where I'm just using Y to represent the ratio. The wave travels the same speed V in the medium of flesh (roughtly) hence;
Y = ( V/f ) / (V/f0)
Rearrage for f;
1 / [(Y*( V / f0 )) / V ] = f
However that might not be the question being asked or not, as you would require extra infomation to solve that numerically.
Haths
How do I solve for the wavelength if the wavelength is not given?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
