Fortran Fortran - How to retrieve read near middle or end of large file quickly.
  • Thread starter Thread starter jtibbitt
    File Fortran
To retrieve information from a file without reading all preceding data, using direct access files is recommended. This method allows for reading specific records based on their fixed length, which is suitable for the given data structure. By correctly defining the open statement, you can access the desired coordinate pair directly. For further guidance, reviewing resources on direct access file handling in Fortran can provide additional examples and insights.
jtibbitt
Hi. I need to be retrieve information far into a file without reading everything before it. Is there a way to do this? Current code is below.
Thanks,
Jeff Tibbitt
!ccccccccccccccccccccccccccccccccccccccc
program getcoord
integer i
real*4 xx(1000), yy(1000), zz(1000)
double precision x(1000,3)
! FILE
open(unit=56,file="tmp.dat",form='unformatted')
do i=1,50000
! GET 50000th SET OF COORDINATES
read(56) xx
read(56) yy
read(56) zz
enddo
close(56)
! CONVERT TO DOUBLE PRECISION
do i=1,1000
x(i,1)=xx(i)
x(i,2)=yy(i)
x(i,3)=zz(i)
enddo
end program
Technology news on Phys.org
I believe you can try reading it as a direct access file.
Direct access files can be formatted or unformatted, but each record has to have a fixed length, which I believe applies in your case.
If you define the open statement correctly, the record number would be the coordinate pair you are trying to read, as in the above example.
Try reading up (the later part of) the following article on direct access file and the examples:
http://www.amath.unc.edu/sysadmin/DOC4.0/fortran/prog_guide/2_io.doc.html
Yes, that seems to be exactly what I need. Thank-you.
Jeff
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
