How Can Non-Expressional Curves Be Used to Measure Energy Transfer?
  • Thread starter Thread starter johnintheuk
    Curve
Non-expressional curves can be challenging for measuring energy transfer between systems, particularly when using absorption and drive curves that lack mathematical expressions. Integrating the curves is a common approach, but the absence of a clear expression complicates this process. Alternatives discussed include manually measuring areas by drawing the curves or using digital tools to scan and analyze the curves for enclosed areas. However, sharp deviations in the curves necessitate dividing the x-axis into numerous sections for accurate measurement. Continuous data may allow for the derivation of a mathematical expression, which could simplify the analysis.
johnintheuk
I'm trying to find the quantity of energy transferred between two systems. I have an absorption curve and a drive curve, but neither of these follow a mathematical expression.
I want to use the absorption curves to find out how much of the drive is being transferred. I know one way to do this would be to integrate the curves, but they can't really be approximated by an expression.
How else might I go about it?
I have actually thought about drawing them, then doing the old cutting out and measuring the area trick for a rough estimation. Surely there's something easier than that though.
Maybe scan them and use something on the computer to find the enclosed area?
But there's a lot of sharp deviation on the curves, so I'd really need to cut the x-axis up into a lot of sections to get any kind of accuracy whatsoever.
"math expression" means what to you?
Do you have some data that we could look at or a plot?
As long as the data is continuous, a math expression should be possible to find. See this http://www.digitalCalculus.com/demo/curvfit.html" program with its many examples.
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
