Calculating a value of force using vectors?
To calculate the value of p in the force equation, start by combining the forces from all four people pulling the box. The resultant force is given as (33i + 96j)N plus (100i + pj)N, which equals k(12i + j). By separating the i and j components, evaluate k using the i part and then use that value to solve for p in the j part. The method of adding the forces and dividing to find proportions is correct, but ensure the focus is on solving for p, not j. The approach outlined is valid for determining the unknown force component.
xllx
A box is being pulled with a resultant force of (33i+96j)N by 3 people. Another person starts pulling the box with a force of (100i+pj)N. With all 4 people pulling the box, it moves in the direction of (12i +j). I need to work out the value of p.
For this would I add 100 and 33, and then divide by 12 to find the proportions of i. And then with that times it by the 1j to get what j is.
E.g.
100+33=133
133/12=11.1
1x11.1=11.1
96+j=11.1
j= -84.9
Or is this totally wrong?
Any help at all would be greatly appreciated. Many Thanks!
Correct!
Might be easier to follow if you put
33i+96j + 100i+pj = k(12i+j)
Separate the i part from the j part. Use the i part to evaluate k, then use it in the j part to find p.
E.g.
100+33=133
133/12=11.1
1x11.1=11.1
96+j=11.1
j= -84.9
That looks correct. Of course you are finding p and not j, but the method looks ok.
