How Does the Force on a Particle Change with Position in a Potential Well?
  • Thread starter Thread starter bakin
    Force Potential
The discussion revolves around calculating the force on a particle in a potential well defined by the equation U(x) = 1.8x² - 4.5 J. The participant initially differentiated the potential energy function to find the force, resulting in F(x) = 3.6x, but encountered issues with the calculations at specific positions. They correctly identified that at x = 0 m, the force should be zero, but expressed confusion over the division by zero. Ultimately, the participant realized their initial calculations were correct but had made an error in significant figures when submitting their answers. The thread highlights the importance of careful calculation and attention to detail in physics problems.
bakin
A particle is trapped in a potential well described by U(x)= 1.8 x²-b where U is in joules, x is in meters, and b = 4.5 J.
Find the force on the particle when it's at x = 2.8m
Find the force on the particle when it's at x = 0 m
Find the force on the particle when it's at x = -1.4 m.
F(x) = -dU(x) / dx
so I just differentiated U(x), slapped a negative sign, and ended up with F(x) = 3.6x
Plugged in 2.8m, ended up with -10.08, and it ain't right. Any ideas why? I'm thinking it might have to do with the phrase "potential well".
Never mind :blushing:
F(x) = U(x) / x
edit: (never mind)² by using this, part B came out correct, (the answer would be zero), but it doesn't make sense. By plugging zero in there, you're dividing by zero, which is ILLEGAL. so i guess I am back here for help, lol.
edit: (never mind)³ /sigh the way i had it originally was correct, but online I put in the wrong number of significant figures. oh well.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
