Equation of relation that has mulitple y points
  • Thread starter Thread starter Learner
    Points Relation
The discussion centers on finding a function F that maps a set of natural numbers X to multiple candidate outputs from sets Y, where each input x corresponds to a unique set of possible outputs. The user seeks the smallest degree function that can accurately represent this relationship, without being limited to polynomial forms. They hypothesize that the existence of multiple candidate y points for each x could allow for a more efficient function than traditional curve fitting methods, which typically focus on a single output. The conversation also references Lagrange's interpolation formula, noting that while n points can be fitted with an (n-1) degree polynomial, the goal is to explore alternative approaches that leverage the redundancy of multiple outputs. The user is open to suggestions for techniques or forums better suited for this inquiry.
Learner
Hi, well I need something close to curve fitting. But I am not sure if it could serve the purpose. The problem is as below:
Suppose, I have the following relation X r Y. Here X is a natural number set. Suppose we have "k" sets,D1,D2,..Dk of selected datapoints over natural number, such that the intersection of all Di's is null set. Let Y be a set of all Di's.
The relation relates every x, to a set of possible data point sets in Y.
As an example see this, here we have k=3.
X Y
1 {2, 4, 5, 10, 12, 13 }
2 { 3,7,8,9,11,14}
3 {1,6, 15,17, 20, 22}
4 {2, 4, 5, 10, 12, 13 }
5 { 3,7,8,9,11,14}
The question is to find the Smallest equation/function F that Exactly fits the given data in such a way that F(x) just outputs anyone of the datapoint from the Di. I do not need the whole Di.Just anyone of the value from Di.
As an example, the F may be
X Y
1 2
2 3
3 1
4 2
5 3
I need to find the relation F :)
Well, I am looking for the smallest degree function. There is no restriction that it should be polynomial even.( May be aCos(x)+bSin(x) etc. ). What I am looking for is a technique that can take advantage of the fact that it has multiple candidate y points for each x. Many traditional curve fitting techniques tend to fit the curve around one y point.
My hypothesis is that since we have multiple candidate y points for each x, one can exploit this redundancy, and might be able to get a function much smaller than (n-1) polynomial. How true is this ?
If you know that I have chosen the wrong forum, please point me to the right place. Thanks
Mathematics news on Phys.org
My hypothesis is that since we have multiple candidate y points for each x, one can exploit this redundancy, and might be able to get a function much smaller than (n-1) polynomial. How true is this?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
