Equation of Asymptote (Hyperbola)
The hyperbola with vertices at (3,0) and (-3,0) is represented by the equation 49x^2 - 49y^2 = 441. However, there is confusion regarding the asymptote y = 7/3x, as it suggests a different relationship than what the derived hyperbola equation indicates. The asymptotes for the hyperbola should be y = x and y = -x, based on the standard form of hyperbolas centered at the origin. The discussion highlights that if y = 7/3x is indeed an asymptote, it contradicts the derived hyperbola equation. The conversation concludes with a request for further clarification on how to reconcile these findings.
jOANIE
What is an equation for the hyperbola with vertices (3,0) and (-3,0) and asymptote y=7/3x?
I solved this problem but still have a question. The answer is 49x^2-49y^2=441 (I solved it by graphing). However, my question: How do I derive the equation for the asymptote y=7/3x?
You can't. If the asymptote is really y= 7/3 x, then 49x^2- 49y^2= 441 is wrong.
As x and y get very large, "441" will be very very very small in comparison with 49x^2 and 49y^2 and can be neglected. That is the graph will be very close to the graph of 49x^2- 49y^2= 0 which is the same as x^2- y^2= (x- y)(x+ y)= 0[/math] so y= -x and y= x are the asymptotes.<br /> <br /> If y= (7/3)x is an asymptote and the vertices are (-3,0) and (3,0) then the hyperbola is symmetric about the x-axis and y= (-7/3)x is also an asymptote. Of course y= (7/3)x is the same as 3y= 7x or 7x- 3y= 0. That means that, for large x and y, the graph is close to (7x- 3y)(7x+ 3y)= 49x^2- 9y^2= 0. Can you complete the problem from there?
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
