Horizontal Eavestrough Problem
  • Thread starter Thread starter ghostanime2001
    Horizontal
ghostanime2001
A horizontal eavestrough 3m long has a triangular cross section 10 cm across the top and 10 cm deep. During a rainstorm the water in the trough is rising at the rate of 1 cm/min when the depth is 5 cm.
a) How fast is the volume of water in the trough increasing?
b) After the rain stopped, the water drained out of the trough at the rate of 0.06 m3/min. How fast is the surface of the water falling when the depth is 1 cm?
V =\frac{1}{2} bhl
Solving in terms of b:
b 5
h 10
V =\frac{1}{2} bhl
b 5
h 10
I'm not entirely sure what you're doing here. You're given dl and dh at a certain time and you're asked to determine dV.
I know this formula that relates Volume with base, height and length of the water trough. The formula is V=1/2 bhl
From similar triangles:
5/10 = b/h
5h=10b
b=5/10 h
b=1/2h
Then substituting 1/2h for b into the formula we get:
V=1/2(1/2 h)hl
V=1/2(1/2 h2 l)
V=1/4 h2 l
Now differentiating h we get:
dV/dt = 2(1/4)h dh/dt l
dV/dt = 1/2h dh/dt l
Now submitting in all the values we get:
dV/dt = 1/2(5 cm)(1 cm/min)(300 cm)
dV/dt = 750 cm3/min
However the answer is 1500 cm3/min. Now my question is WHAT HAPPENED!? i did everything correct from everything I've learned but i still don't get the correct answer... :( please help me understand thank you.
as for b) ill wait until i get the first part correct.
When the trough is full b=10, and h=10. When the trough is half full b=5 and h=5, right? The correct relation is b=h, not b=(1/2)h. I would rethink the logic that lead you to that.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
