What is a Suitable Projectile for a Small Trebuchet?
A suitable projectile for a small trebuchet with a base of 75 cm² is challenging, especially when aiming for a 5-pound weight that can fit in a spoon. Concerns arise about the stability of launching such a heavy projectile from a small base, suggesting that it may not be practical. The discussion humorously touches on the difficulty of finding a household item that meets these specifications. Overall, the feasibility of launching a 5-pound projectile from a small trebuchet is questioned, indicating potential design issues. The conversation highlights the need for careful consideration of weight and stability in trebuchet construction.
davie08
all I really need right now is a 5 pound small weight that can fit in a spoon but I don't think there is anything that size that can fit in a spoon that would be lying around a house so what is a good projectile for the trebuchet the size of this one which will have a base of 75cm^2 or about 38 inches^2.
Are you sure you want to be making a trebuchet that can launch a 5 pounder? from a 75 cm2 base? Seems mighty unstable for so much energy to launch.
As to something that weighs 5 pounds and will fit in a spoon, I could recommend a couple of bad restaurants that served something similar and was good for hurling ... but I think you have something else in mind.
