Is This Expression a Tautology?
  • Thread starter Thread starter aeronautical
aeronautical
Determine if the following is a tautology:
((p → q) Ʌ (q → p) → (p Ʌ q)
I don´t know how to show this. Can somebody pls show me all the steps
Make the following table:
p|q|p → q|q → p|(p → q) Ʌ (q → p)|p Ʌ q|((p → q) Ʌ (q → p) → (p Ʌ q)
T|T|
T|F|
F|T|
F|F|
Now finish this table, if the last column yields true for all possible values for p and q then ((p → q) Ʌ (q → p) → (p Ʌ q) is a tautology.
T|T|
T|F|
F|T|
F|F|
im sorry but I am lost. this is very tricky. i don't understand this table
I have basically chopped your original expression into chunks. Every column of the table has a term of the original expression in it and I have used | to separate the columns. The last column has the entire expression in it.
Lets finish the first row:
p and q are true so q->p is true and p->q thus (p → q) Ʌ (q → p) is true. On the other hand we have p Ʌ q which is true so now we have all components that we want. So we can conclude, since (p → q) Ʌ (q → p) is true and (p Ʌ q) is true, ((p → q) Ʌ (q → p) → (p Ʌ q) must be true.
Now try to work your way through the other values of initial p and q. Note that I put all possible combinations in the first two columns.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
