Maxwells equation and Doppler Shift.
Maxwell's equations describe the relationship between electric and magnetic fields, which propagate at the speed of light. When radiation reflects off a perfect conductor, it ideally reflects all energy, but if the mirror moves, the reflected light experiences a drop in frequency and power, linked to the mirror's acceleration. The momentum transfer during reflection is calculated using the relationship p = E/c, but when applying this to a moving mirror, the assumption of constant velocity complicates the energy transfer analysis. The discussion highlights that while photons may lose energy (frequency decreases), the amplitude of the wave remains unchanged, leading to a paradox in energy conservation. Ultimately, the interaction suggests that more photons are present despite the lower energy per photon due to the Doppler effect.
andrewr
I am trying to grasp how Maxwell's equations and energy/photons are related in a doppler shift problem.
The way I stated it seems to have attracted non-serious hecklers; so I am trying to restate the problem for people who know Maxwell's equations and are familiar with engineering.
In Maxwell's equations, there are E & H fields which propagate at velocity=c as the the change in the E field generates a H field and vice versa.
When radiation is incident on a perfect conductor (or appropriately designed dielectric reflector) 100% reflection of the energy occurs. For example, a perfect mirror or polished superconductor bolted down to a table -- and a laser bouncing off that mirror.
If one allows the mirror to move -- say, in an attachment to a crooks tube radiometer -- the reflected light drops in frequency and power. The drop in power is related to the acceleration of the mirror which receives 2x the momentum of the energy striking it.
Maxwell predicted that -- the momentum transfer being power/area * area * time / c; eg: p= E/c
In my EE class, we worked problems of maxwell's TEM waves normally incident on a reflector by setting the boundary conditions such that the E field is zero inside the conductor/mirror, and assuming plane waves that meet the boundary condition.
The reflected wave has the same amplitude as the incident wave -- so we know that all the energy is reflected.
However; when the same technique is applied blindly to a moving mirror (with constant velocity non-relatavistic speed) the reflected wave frequency drops -- but the amplitude does not.
Why?
I see your point. Although the photons seemingly lose Energy according to W=h\nu the classic definition of energy for a normal wave would be W=E^2 and the amplitude does not change.
The reason why your calculation must be too naive is this: when you only account for the transferred momentum to the mirror, you completely disregard the weight. Actually you are saying that the weight is infinite since you assume is is at constant velocity, so the momentum transfer doesn't effect it.
For this reason and because W=\frac{p^2}{2m} the mirror cannot receive energy.
So your calculation seems to be correct, if you do not accelerate the mirror, because it is too heavy, then the light wave will not lose energy, even though the photons have a lower frequency.
To kill the follow up question: So do we have more photons now? Yes we do.
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
