Calculating base ionization constant from a known pH and concentration
The discussion focuses on calculating the base ionization constant (Kb) for ammonia using its initial concentration and pH. The initial concentration of NH3 is stated as 3.708 mol/L with a pH of 10.26. The participant attempts to use an ICE table to determine the equilibrium concentrations and Kb but expresses confusion regarding the values derived from the pH and titration data. They question the accuracy of the initial pH measurement, suggesting that a pH of 10.26 would indicate a much lower concentration of ammonia than reported. The participant ultimately concludes that their calculated Kb value deviates significantly from known values, indicating potential errors in their initial assumptions or measurements.
doggbAT
In this experiment you will find the ionization constant for ammonia, a weak base.
I have completed the experiment, and have the following:
Initial concentration of NH3: 3.708mol/L
Initial pH of NH3: 10.26
NH3(aq) + H2O(l) <--> NH4+(aq) + OH-(aq)
pH = -log[H+]
Kb = [NH4+][OH-]/[NH3]
I previously had no idea what to do, but now looking at the ICE table I have...
NH3 + H2O <--> NH4 + OH
I 3.708 - 0 0
C -x - +x +x
E 3.708-x x x
Correct me if I'm wrong, but...
Would the E value of NH3 not be 0?
And wouldn't the E values of NH4 and OH be 3.708?
Thanks, doggbAT
This is just not sufficient.
How about a pH titration as additional information?
Okay I figured out that the information I gave was wrong.
I measured the pH of the NH3 in its source bottle to be 10.26
I then titrated it with 9.275mL of .0100mol/L HCl.
I calculated the amount of HCl to be 9.275x10-5mol.
Based on the equation HCl(aq) + NH3(aq) <--> NH4+(aq) + CL-(aq), I assumed that the amount of HCl is equal to the amount of NH3.
Therefore, the amount of NH3 is 9.275x10-5mol.
I then used that amount to determine the concentration to be 3.708mol/L
I do not understand when this concentration of NH3 is true. I went under the assumption that it was the concentration of the original bottle of NH3. I used the pH of the original bottle to determine the [H+], then the [OH-]. I made an ICE table, and subbed the known [OH-] value into it. I determined that kb = [NH4+][OH-]/[NH3] and solved for kb accordingly. However, when I calculated the percent difference between this and a known kb value for ammonia, I got 199%. I don't think my titration skills are that bad.
My bet is that your initial pH is wrong. pH 10.26 gives ammonia concentration in the range of 10-3M. Molar concentrations mean pH close to 12.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
