FLRW Metric Tensor: Calculating g^{ca}g_{ab}
trv
Not really homework, but thought this might be the best place to get a quick answer.
Question
Calculate g^{ca}g{ab} for the FLRW metric.
I would have thought this would be
<br /> g^{ca}g{ab}=\delta^c_b=4<br />
I thought 4 because I assumed there should be "1" for each non-zero element in the metric tensor g_{ab}.
Apparently however it should be g^{ca}g_{ab}=1
Can anyone please explain why?
This is just the Kronecker delta which is 1 if b=c and zero if not, there is no summation going on. If it had been \delta_b^b Einstein summation would have been implied, which would yield 4.
Mathematically:
<br /> A^\gamma=g^{\gamma \alpha}A_\alpha= g^{\gamma \alpha}g_{\alpha \nu}A^\nu=\delta_\nu^\gamma A^\nu=A^\gamma<br />
If it were four, you would get A^\gamma=4A^\gamma which would make little sense.
Thanks again Cyosis that clears things up.
Actually, another quick question.
So the tensor, g^a_b for the FLRW metric, simply has components 1 along the diagonal?
Or for that matter, to generalise it further. Given any metric tensor r_{ab} with all elements being non-zero, r^a_b has components 1 everywhere?
To add to that, given,
<br /> L=-0.5(\frac{d\phi}{dt})^2+V(\phi)<br />
does g^a_bL = L?
Correct.
No, proof:
<br /> r^\alpha_{\;\;\beta}=r^{\alpha \gamma}r_{\gamma \beta}=\delta^\alpha_\beta<br />
In words, any mixed metric is equal to the Kronecker delta. You basically have a matrix with 1's on the diagonal and zeros elsewhere.
Oh yeh, true the kronecker delta would imply zeros everywhere apart from the diagonal. I think where I'm going wrong is assuming we multiply each element by its inverse. Giving 1 at all places where the metric tensor had non-zero components. Obviously that's not how it works.
Think of these tensors as matrices, where g^{ab} is the inverse of g_{ab}. Just as multiplying a matrix with its inverse yields the identity matrix (AA^{-1}=I), multiplying the metric with its inverse yields the kronecker delta.
Thanks the two of you.
