Taylor series of two variable ?
To calculate the required number of terms for a given decimal accuracy in a two-variable Taylor series, one can adapt the error term used in the one-variable case. The error term for two variables involves a summation of partial derivatives of the function, evaluated at a point 'e' between the center 'c' and the variable points. To achieve a specific accuracy, such as three decimal places, the error term must satisfy an inequality similar to the one-variable case. Resources or tutorials on multivariable calculus can provide further guidance on applying this concept. Understanding the two-variable Taylor series and its error estimation is crucial for accurate calculations.
rclakmal
I want to know that how to calculate the required number of terms to obtain a given decimal accuracy in two variable Taylor series .
In one variable case i know there is an error term R(n)=[ f(e)^(n+1)* (x-c)^(n+1)] / (n+1)! where 'e' is between x and c (c is the center value ) so if we want a 3 decimal place accuracy we can have the inequality below
R(n)<=5*10^(-4) then we can obtain particular ' n ' to have that accuracy
But i don't know how to use this in two variable case .please give some explanation or a good tutorial where i can learn it .
The corresponding formula for two variables is
R(n)= \sum_{i=0}^{n+1} \frac{\frac{\partial^{n+1} f(e)}{\partial x^{i}\partial y^{n+1-i}}(x-c)^{n+1}}{(n+1)!}
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
