Reduction of differential equations then numerical methods
danielL
I have a function that attempts to imitate the internal forces of the cord used for bungee jumping. I have been told to resolve it using Runge-Kutta 1st order numerical aproximation, therefore i have to reduce it to a system of equations. The preffered Runge-Kutta method is euler forward: y1 = y0 + k1 where k1 = h*f(y0). Plus I have to do this in a spreadsheet.
M*q''(t)+K*q(t)=b(t)
Where M and K are 3x3 matrix and k and b are vectors with 3 components
If I make q'(t) = v(t)
then v'(t) = M^(-1)*[b(t)-K*q(t)]
i can divide v'(t) = M^(-1)*b(t)+[-M^(-1)*K*q(t)]
and then obtain a vector plus matriz to solve it. My problem is that i don't know how to take the data from the matriz and apply it.
Thanks
Your differential system (written as a system of first order differential equations) is:
<br /> \left[ \begin{array}{1c}<br /> q&#039; \\<br /> v&#039; \\<br /> \end{array} \right] = \left[ \begin{array}{1c} v(t) \\ M^{-1}b(t)-M^{-1}Kq(t) \\\end{array} \right]<br /> <br />And so your Runge-Kutta numerical method is:
<br /> \left[ \begin{array}{1c}<br /> q_{n+1} \\<br /> v_{n+1} \\<br /> \end{array} \right] = \left[ \begin{array}{1c} v_{n} \\ M^{-1}b(t_{n})-M^{-1}Kq_{n} \\\end{array} \right]<br /> <br />
supposedly you have the intial values vo, qo, so you go on generating the solution at the mesh points ti=i*h, where h is your step-size. The matrix M is constant so all you have to do is invert it and use it as I've indicated above to generate your numerical solution . . . in your spreadsheet go on generating the solution for each time step in a new row of cells based on the value of the previous time step which you take from the previous row of cells and the values of the components of K, M^(-1) and b which you store in a separate set of cells (you can evaluate b(tn) in a separate cell at each time step) , . . . um, I'm not sure if I understand your question altogether lol.
Yeah actually i read my message back, and it was kind of funny, my problem was that the graph didn't end up the way i was told it was supposed to look like. Ended up being a problem of both the method selected and the step i had chosen, fixed those and it fell into place.
I'll attach it when i get home in case anyone else was pondering the problem, thanks for responding
Oh I see, okay:) yes, the numerical method you chose is an explicit one and has a certain region of absolute stability that limits the step-size you can use for it to work well . . .
glad you sorted it out :)
yeah that was exactly the problem, function went haywire
thanks for the support
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
