Can a standard ATV handle speeds over 100mph and still turn safely?
  • Thread starter Thread starter UnteljentEnginyr
Standard ATVs are not designed to safely handle speeds over 100 mph, primarily due to their narrow wheelbase and high center of gravity, which increases the risk of flipping during turns. Riders can experience significant difficulties in maneuvering at high speeds, as the tires are often unbalanced, exacerbating stability issues. Even modified ATVs, like the Yamaha Tri-Z 250cc and Banshee, can be challenging to control at speeds above 70 mph. Tight cornering is particularly dangerous, and body weight transfer becomes critical for maintaining control. Overall, high-speed ATV riding should only be attempted by experienced individuals with appropriate safety gear.
UnteljentEnginyr
Take your standard to large size ATV and make it go over 100mph. Will it be able to turn...at all? I would imagine that there would be a lot of difficulties just because the wheel base (dont know if that is the term or not...I mean the distance between the two front or the two rear tires) is not very wide, as compared to a car that's designed to go over 100mph.
When I think of something like this, I am imagining getting it up over 100mph, trying to turn, only to have the thing flip on its side...many many times.
I used to own a highly modified Yamaha Tri-Z 250cc three-wheeler. It'd do 90MPH+ but was an absolute handful at speed. Even at 60-70MPH it was quite an adreneline rush to move over on a gravel road, the short wheelbase meant things happened quickly and the nature of being a 3-wheeler made it twitchy as well. I have a cousin with a modified Banshee, it handles pretty well at 70-75MPH in comparison.
You can't turn tight corners unless you want to end up like Ozzy, but they can still change directions even if only slowly on long sweeping gradual curves. The bigger problem is the tires aren't balanced and this is a huge issue at speed.
The high center of gravity and solid rear axle doesn't help either which is why transferring your body weight is even more important than at low speeds. Don't try it at home unless you're experienced, never ride beyond your skills, and always with the right protective gear kinda thing.
Cliff
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
