Build a Pump Using Wind Generator Design
  • Thread starter Thread starter quantoshake11
    Pump
The discussion revolves around the idea of repurposing a wind generator design to create a water pump by reversing its operation. The proposed design involves using a wheel with magnets inside a tube, while the coils would be positioned outside. Concerns are raised about the efficiency of this setup, with suggestions that it may function more like an inefficient fan rather than an effective pump. The creator expresses hesitation about starting the project due to time and cost considerations, while also noting potential applications beyond just pumping water. Overall, the feasibility and efficiency of the design remain in question, with a humorous suggestion to place it under an air conditioner for added energy.
quantoshake11
hi, I've been inspired by this wind generator design: http://www.instructables.com/id/Pringles-Wind-Turbine-Pleech---Version-One/
to make it operate in reverse, that is, feed alternating current and make the thing spin.
The purpose of this is to make a pump by putting a wheel (similar to those seen in airplane turbines) inside a tube, and fixing the coils outside of the tube. The weel would have magnets attached at the rim (like the one in the generator). Do you think that it would work? would i need to synchronize the current so the wheel won't jam? what advices can you give me?
You would basically just be making a very inefficient fan. You could do it, but I don't know why you would.
It's a very inefficient generator that steals energy from your air conditioner fan.
hi, i still got to get my hands dirty and i can't find the time or motivation to get going (and i don't want to spend the money in buying materials unless I'm 100% sure I'm going to go through the whole way). The end product i have in mind would be a tube section with a fan at the middle, and the wires outside, so with the proper fan i could have a way to pump water through the tube. My first idea was to use it in a hydroponic system, but if the fan is made properly i see no reason why it would be limited to water.. I've heard that most water pumps should not be operated without water, but this one should work either way.
you can always put it beneath somebody else's air conditioner :D
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
