Understanding Probability Distributions for Generating Random Data
  • Thread starter Thread starter EliteLegend
    Numbers Random
The discussion focuses on using the Pareto Distribution to generate a dataset based on the 80/20 rule. A specific challenge is presented: generating 40% of 50 items 60% of the time. One suggested method involves duplicating items to achieve the desired proportions before making selections. For example, to select one item 67% of the time, duplicating that item allows for a straightforward random draw. The conversation emphasizes understanding probability distributions to effectively manage random data generation.
EliteLegend
I have recently come across the 80/20 rule... I am using the Pareto Distribution's pdf to generate some dataset that I wanted... Now if I have a set of 50 items and I need to generate 40% of these items 60% of the times, how am I supposed to go about doing this? I know how to select items with certain probabilities but this task is confusing me... Anyone has some inputs for me please?
One way is to create duplicate (multiplicate) items until you reach the desired proportion, then use a uniform rule to select.
For example, if I had 2 items {x, y} and wanted to obtain x 67% of the time, I'd duplicate x once, and make draws from the set {x, x, y}.
To select one of m items, from a total of n items, a proportion y of the time, you need to select each of the m items with probability y/m, and each of the remaining n-m items with probability (1-y)/(n-m)
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
