Purpose of Entrance Slit in Spectrometer: Rgds Evidenso
  • Thread starter Thread starter evidenso
    Slit Spectrometer
The entrance slit in a dispersive spectrometer narrows spectral lines and helps maintain focus by ensuring light is projected at a single spot, enhancing resolution. While not mandatory, many designs, such as Echelle spectrometers, incorporate entrance slits for improved transmission efficiency and aberration correction. The slit also facilitates the daisy-chaining of multiple spectrometers for finer spectroscopic detail. It is important that the slit size is optimized to avoid significant diffraction effects. Overall, the entrance slit plays a crucial role in the performance and functionality of spectrometers.
evidenso
Hi
Can anyone tell me the purpose of a entrance slit in a dispersive spectrometer. What is it good for? I guess it will create a single slit diffraction pattern. Why will this make the resolution better, instead of just colliminate the beam?
Will the slit do some kind of Fourier filtering also?
Rgds
Evidenso
The slit should not be so small that there is notable diffraction from it. Its purpose is simply to make the spectral lines narrow. Consider that even monochromatic light entering a prism at a different spot will be projected at a different spot. So the slit keeps it to one spot.
An entrance slit is not a requirement, but it's true that many spectrometer designs (Echelle, use entrance slits.
One reason is overall transmission efficiency and aberration correction- some designs are kinda like imaging systems in that the exit slit is an image of the entrance slit.
Another reason is so that multiple spectrometers can be daisy-chained together to provide ever-finer spectroscopic detail.
Chapter 8 of the Richardson Grating Handbook has addtionial details:
http://gratings.newport.com/handbook/handbook.asp
Hi
Thanks, very helpful.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
