Contravariant derivative tensor problem
rafal_
Tensor \left (<br /> \begin{array}{cc}<br /> 1\\1 <br /> \end{array}<br /> \right ) is T=T^\alpha_\beta \omega^\beta \otimes \vec e_\alphaWhy is contravariant derivative tensor \left (\begin{array}{cc}1\\1 \end{array}<br /> \right )
V^\alpha_{;\beta}\vec {e_\alpha} - contravariant derivative
I don't understand the question. What do you mean by contravariant derivative? Do you mean covariant? What do you mean by those matrices? Are you saying that the components of T in the basis you're considering are (1,1)?
I made a mistake I meant covariant. T is general tensor. I don't understand why
\frac{\partial \vec V}{\partial x^\beta}=V^\alpha_{;\beta} \vec e_{\alpha}
can be associated with a (1,1) tensor
A covariant derivative is per definition a derivative which transforms as a tensor. Loosely, the covariant derivative of a tensor T adds another covariant index, so if T is type (k,l) then the covariant derivative of T is type (k+1, l) (I always forget the convention, but here the k is the number of covariant indices).
Here's a nice exercise: you know how the components of a vector V tranform:
<br /> V^{\mu&#039;}(x&#039;) = \frac{\partial x^{\mu&#039;}}{\partial x^{\nu}}V^{\nu}(x)<br />
You also know how a partial derivative transforms:
<br /> \frac{\partial}{\partial x^{\lambda&#039;}} = \frac{\partial x^{\alpha}}{\partial x^{\lambda &#039;}}\frac{\partial}{\partial x^{\alpha}}<br />
Now calculate the transformation the components of the partial derivative of a vector:
<br /> \frac{\partial}{\partial x^{\lambda&#039;}}V^{\mu&#039;}(x&#039;) = \frac{\partial x^{\alpha}}{\partial x^{\lambda &#039;}}\frac{\partial}{\partial x^{\alpha}} [\frac{\partial x^{\mu&#039;}}{\partial x^{\nu}}V^{\nu}(x)]<br />
If you write this out, you'll see that this doesn't transform as a (1,1) tensor as you would naively expect on basis of the index structure of the expression. However, in derivatives you compare tensors at different points on the manifold and you need a certain prescription to perform this comparison: the connection \Gamma.
If you want to write things down with a basis, you can define the connection and the covariant derivative as
<br /> \nabla_{\mu}e_{\nu} \equiv \Gamma^{\lambda}_{\mu\nu}e_{\lambda}<br />
Here \nabla_{\mu} means covariant derivation with respect to the basis vector
e_{\mu} = \partial_{\mu}
This second-last formula states that the covariant derivative of the basis vector should be expressible in terms of your basis vectors. If you then write down a tensor in a certain coordinate basis, you can act on this tensor with the covariant derivative. For instance,
<br /> \nabla_{\mu} (V) = \nabla_{\mu}(V^{\alpha} e_{\alpha}) = [(\nabla_{\mu}V^{\alpha})e_{\alpha} + V^{\alpha}\nabla_{\mu}e_{\alpha}]<br />
Demanding that the covariant derivative acting on scalar functions gives the same result as a partial derivative (and some basic rules such that it obeys Leibnitz), you arrive at the same answer as in a component-only treatment.
Hopefully this makes things a bit clear :)
I like the approach to covariant derivatives that starts with a connection. I'll quote myself (and fix a couple of mistakes at the same time):
Fredrik said:
Let V be the set of smooth vector fields on a manifold M. A connection is a map \nabla:V\times V\rightarrow V such that
(i) \nabla_{fX+gY}Z=f\nabla_X Z+g\nabla_YZ
(ii) \nabla_X(Y+Z)=\nabla_XY+\nabla_XZ
(iii) \nabla_X(fY)=(Xf)Y+f\nabla_XY
\nabla_XY is the covariant derivative of Y in the direction of X. The covariant derivative operator corresponding to a coordinate system x is
\nabla_{\frac{\partial}{\partial x^\mu}
The notation is often simplified to
\nabla_{\partial_\mu}
or just \nabla_\mu.
The above only defines the action of \nabla_X on vector fields, but note that condition (iii) above suggests a way to extend the definition to scalar fields. If we define
\nabla_Xf=Xf
condition (iii) looks like the Leibnitz rule for derivatives:
\nabla_X(fY)=(\nabla_Xf)Y+f\nabla_XY
So we choose to define \nabla_Xf that way. Can we do something similar for covector fields? It turns out we can. Suppose that \omega is a covector field. The closest thing to a Leibnitz rule we can get is this:
\nabla_X(\omega(Y))=(\nabla_X\omega)(Y)+\omega(\nabla_XY)
so we choose to define \nabla_X\omega by
(\nabla_X\omega)(Y)=\nabla_X(\omega(Y))-\omega(\nabla_XY)
for all Y. Note that this means that we define \nabla_X\omega to be a covector field.
The same idea can be used to find the appropriate definition of \nabla_X acting on an arbitrary tensor field. You can probably figure it out on your own.
Don't forget that the covariant derivative you're used to is the special case X=\partial_\mu.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
