If nucleons are held together by residual strong force could could gravity be residual residual strong force reaching outside the atom, causing atoms to tend to clump together?
No, for one thing the theory of the strong interaction that we have says that the force strength drops off much too quickly, and this theory has been tested in enough detail to not doubt its validity from the largest distance scales to the smallest that we've probed. When you put a large number of atoms together, they don't increase the range of the strong interaction. On the other hand, the gravitational force has a "long range" so if you put many contributors (atoms) together to form e.g. a planet, you and other objects far away can feel the effects.
This is an alert about a claim regarding the standard model, that got a burst of attention in the past two weeks.
The original paper came out last year:
"The electroweak η_W meson" by Gia Dvali, Archil Kobakhidze, Otari Sakhelashvili (2024)
The recent follow-up and other responses are
"η_W-meson from topological properties of the electroweak vacuum" by Dvali et al
"Hiding in Plain Sight, the electroweak η_W" by Giacomo Cacciapaglia, Francesco Sannino, Jessica Turner
"Astrophysical...
https://arxiv.org/pdf/2503.09804
From the abstract:
... Our derivation uses both EE and the Newtonian approximation of EE in Part I, to describe semi-classically in Part II the advection of DM, created at the level of the universe, into galaxies and clusters thereof. This advection happens proportional with their own classically generated gravitational field g, due to self-interaction of the gravitational field. It is based on the universal formula ρD =λgg′2 for the densityρ D of DM...
