Help understanding math on inclined plane example
The discussion focuses on understanding the calculus involved in analyzing motion on an inclined plane, specifically in the context of a problem from Marion/Thornton. The user is confused about the integration steps needed to find the velocity of a block moving down the incline after a certain distance. Key points include the application of the chain rule in calculus to relate changes in velocity to acceleration, and the clarification that the limits of integration must correspond to the variable being integrated, which is the square of the velocity. The conversation emphasizes the importance of understanding these calculus principles to solve the problem correctly. Overall, the discussion aims to clarify the mathematical concepts necessary for solving inclined plane motion problems.
jimz
I'm trying to follow a very simple example example in a text (Marion/Thornton example 2.1) and I think my rusty calculus is tripping me up and I'm just being stupid.
I understand how to derive the acceleration down the plane:
\ddot{x}=g\sin\Theta
but next they say 'we can find the velocity of the block after it moves from rest a distance x0 down the plane by multiplying by 2x' and integrating.
2\dot{x}\ddot{x}=2\dot{x}g\sin\Theta
the next steps confuse me...
\frac{d}{dt}(\dot{x}^2)=2g\sin\Theta\frac{dx}{dt}
What happens to the 2 on the left? What am I doing wrong here?
2\dot{x}\ddot{x}=2\dot{x}\frac{d}{dt}\dot{x}=2\frac{d}{dt}(\dot{x}^2)
Next, the limits of integration are chosen:
\int_{0}^{v^2_0}d(\dot{x}^2)=2g\sin\Theta\int_{0}^{x_0}dx
I have no idea what is happening on the left... where do they pull v^2 0 from? What happens to time? What is going on here again.. last time I had calculus was years ago. Thanks.
2VdV/dt = dV^2/dt
They are using the chain rule from calculus.
du/dt = (du/dv) (dv/dt) , where u is a function of v -- i.e. u(v)
Letting u=v2, note that (du/dv) = 2v. So applying the chain rule:
d(v2)/dt = (du/dv) (dv/dt)
= (2v) (dv/dt)
= 2 v dv/dt​
As for the limits on the integral: note that "v2" is the variable that is being integrated. The limits must be in terms of that variable. And since v2 varies from 0 to vo2, those are the limits of integration.
Hope that helps. And welcome to Physics Forums!
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
