Can You Derive F = gamma^3*ma from Newton's Second Law?
  • Thread starter Thread starter beecher
The discussion revolves around deriving the equation F = gamma^3 * ma from Newton's second law, where F = dp/dt and p = gamma * mv. Participants express confusion about the derivation process, particularly how to handle the differentiation of gamma, which is dependent on velocity. Clarifications suggest that instead of integrating, one should directly differentiate and rearrange the terms for simplicity. Key insights include expressing gamma in a more manageable form and using the chain rule for differentiation. The conversation emphasizes the importance of understanding the relationship between force, momentum, and relativistic effects in physics.
beecher
Newton's second law is given by F = dp/dt. If the force is always parallel to the velocity, show that F = gamma3ma
p = gamma*mv
gamma = 1/(1-v2/c2)1/2
I really have no clue where to begin. This is what I've done so far, but I don't think I'm even on the right track.
F = dp/dt = gamma3ma = [1/(1-v2/c2)1/2]3ma
=1/(1-v2/c2)3/2ma
=1/(1 - 3v2/c2 + 3v4/c4 - v6/c6)1/2ma
Thats as far as i get on the right side.
For the left, all i can manage is dp/dt = d/dx p = d/dx gamma*mv
This is where I get confused. gamma and m are constant, so does dp/dt = gamma*m*dv/dt?
Some clarification would be great.
Thanks!
Are you in Modern Physics and answering this for your Russian Prof?
You're taking the hard route, you're trying to integrate the given expression, into the derivative. Just take the derivative, and rearrange.
Some pointers:
Express \gamma=\frac{1}{\sqrt{1-\frac{v^2}{c^2}}}=({1-\frac{v^2}{c^2}})^{-\tfrac{1}{2}
That should make taking the derivative much more simple.
Another bit that should help you is: \frac{d({1-\frac{v^2}{c^2}})}{dt}=\frac{-2v\cdot\dot v}{c^2}
