Calculating forces on a tilting tower
  • Thread starter Thread starter djtexcarr
    Forces Tower
The discussion focuses on calculating forces for a tilting tower with varying loads, specifically an 800-pound load at the top. Key calculations involve creating shear and moment diagrams, which are essential for understanding the structural integrity of the tower. The maximum force in the tower's legs is determined by treating the maximum moment as a force couple, with specific angles measured for accurate calculations. The vertical reaction force at the base of the tower is identified as 497 lbf, and uniformly distributed loads are noted. Resources like statics textbooks are recommended for further understanding of the principles involved in these calculations.
djtexcarr
Please see attached excerpt of a report I have been studying.
I am going to be building a tilt up tower as in the diagram. However, I may be putting varying loads on the tower top, which they indicate to be 800#. On the second page of the pdf, it shows the tower section weights, lengths, etc and it shows the results of the calculations. Could someone please show me how they used the numbers they have to get the conclusions they derived? My goal is to create a spreadsheet in which I can "plug in" the variables and the resulting forces will automatically generate.
Thank you,
David
Creating the shear & moment diagrams is first year structural engineering (end of the year) but not easy to explain, not briefly anyway. Not sure how the maximum force in a leg was determined, perhaps treating the max moment as a force "couple", divided between the legs.
Let's call the two legs at the base of the tower point A, and the point where the cable is attached to the tower point B. It can be figured out that the angle of their cable at point B, measured from a horizontal line, is theta = 24.82 deg. By measuring an enlargement of their diagram, you could measure the angle of their gin pole, and measure the angle of their winch cable. Then, using geometry or trigonometry, you could compute the length of their gin pole. It can be seen in their loading diagram that the vertical reaction force at point A is 497 lbf. And the total load (lbf) for each uniformly-distributed load is written on each uniformly-distributed load, acting downward. As CarlAK mentioned, any statics or mechanics of materials textbook will help you learn shear and moment diagrams. To derive the shear and moment diagrams, which you are asking about, they used statics, or static equilibrium of a simply-supported beam (with overhang).
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
