Prove that if f(a) = 0, then f(x) = (x-a)g(x)
  • Thread starter Thread starter nietzsche
3 replies · 9K views
nietzsche
Prove that if f(a) = 0, then f(x) = (x-a)g(x) where f and g are polynomial functions.
[tex] x^n-a^n = (x-a)h_n(x)[/tex]
where hn(x) is a polynomial function.
[tex] \begin{align*}<br /> f(x) &= f(x) - f(a)\\<br /> f(x) &= [\lambda_n x^n + \lambda_{n-1} x^{n-1} + ... + \lambda_1 x + \lambda_0] - [\lambda_n a^n + \lambda_{n-1} a^{n-1} + ... + \lambda_1 a + \lambda_0]\\<br /> f(x) &= \lambda_n (x^n-a^n) + \lambda_{n-1} (x^{n-1} - a^{n-1}) +...+ \lambda_1(x-a)+(\lambda_0 - \lambda_0)\\<br /> f(x) &= \lambda_n (x-a)h_n(x) + \lambda_{n-1} (x - a)h_{n-1}(x) +...+ \lambda_1(x-a)\\<br /> f(x) &= (x-a)g(x)<br /> \end{align*}<br /> where $ g(x) = \lambda_nh_n(x) + \lambda_{n-1}h_{n-1}(x) +...+ \lambda_1$[/tex]
Now, I think what I've done here is valid. But I assumed that the relevant equation that I posted is true, which (I think) it is. Can someone tell me if this is an acceptable proof?
Thanks.
Is f a polynomial?
That is not true in general.
or do you mean in some limit?
consider
f=exp(x)-1
for a polynomial first prove
f(x)=f(a)+(x-a)g(x)
lurflurf said:
Is f a polynomial?
consider
f=exp(x)-1
f(x)=f(a)+(x-a)g(x)
right, sorry, f is a polynomial. it was the second part of a question, so they had already mentioned that f is a polynomial in the previous part. i'll fix it.
This is correct assuming that you are allowed to use your assumed relevant equation. Did you get it from your book or from somewhere else? If you got it somewhere else, you might want to prove it just to be on the safe side. It's not too difficult.
