Accelerating Charges: Analyzing Test Charge Motion
When a positive test charge is released near a stationary fixed charge, it experiences a force due to electrostatic interaction, leading to acceleration. The question revolves around understanding how this acceleration behaves, particularly whether it is constant or varies. While Coulomb's Law is typically used to calculate the force between charges, it is limited to stationary or slow-moving charges, complicating its application in this scenario. The movement of the test charge depends on the nature of the fixed charge; it will accelerate away from a positive charge and toward a negative charge. Ultimately, the key focus is on the relationship between force, acceleration, and the distance between the charges.
PhyDude
A positive test charge is brought near a stationery fixed point charge. The positive test charge is then released. How does the test charge move after it is released?
a) Constant Velocity
b) Increasing Acceleration
c) Decreasing Acceleration
d) Constant Acceleration
The problem that I had with this question is that after the positive test charge is released, it obviously experiences a force and therefore acceleration but but how exactly is the answer justified. Sure you could use Coulombs law to determine the force but the problem is that Coulomb's Law can't be used because the particle is accelerating and because Coulomb's Law states that the Electrostatic force between two charges can only be determined as long as the charges are stationery or they are slow moving. When charges accelerate, the force that on charge exerts on another is not simply Coulomb's Law.
The question is not asking you to derive a trajectory for the test charge so the specific forces don't seem to be overly important. Yes moving charges create magnetic fields and radiate electomagnetic enegry but considering these things seems to be overcomplicating the question some what.
I think the heart of the problem is:
Is the force that the charges feel dependent on their relative distance?
You have 2 situations either the fixed charge is possitive or negative. How does the test charge move in these 2 cases?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
