Simple Physics Problem - Acceleration Formula
To solve the physics problem of a cart rolling down a 5-meter incline for 6 seconds with an initial speed of 2 meters per second, the acceleration can be calculated using the formula a = (v1 - v2) / t. The final velocity is needed to determine acceleration, which requires understanding the relationship between distance, time, and acceleration. The formula x = x_0 + v_0 t + (1/2) a t^2 can be used, where x is the final position, x_0 is the initial position, v_0 is the initial velocity, t is time, and a is acceleration. Clarification on how to apply these variables is essential for finding the final velocity and subsequently the acceleration. Understanding these concepts is crucial for solving similar physics problems.
Dumblydore
1. A cart is rolling down an incline for 6 seconds. If the cart has a begginning speed of 2 meters per second and the incline is 5 meters long, what is the carts acceleration?
2. a= v1 - v2 / t
3. I'm just learning the acceleration formula in my physics class. I left my science book at school, thinking I would not need it because the worksheet we were given looked simple. But teacher threw in this problem and I'm not sure what to do about the incline. I need my final velocity to figure out the problem, but I'm sure what I do with the 5 meter long incline to get the final velocity.
try to use x = x_0 + v_0 t + (1/2) a t^2
I'm not sure what all the variables in that formula are. I just need someone to explain how to get the final velocity.
x is final position, x_0 is initial position, v_0 is initial velocity, t is time, a = acceleration.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
