Rotational inertia of a THICK spherical shell
8 replies · 10K views
Will
Someone please tell me is I am doing this problem correctly.If I have a thick spherical shell with inner radius r, outer radius R, and mass M, I am getting [(2/5)M/(R^3-r^3)](R^5-r^5). It is not the same thing as subtracting I of large sphere from I of smaller one, different than (2M(R^2-r^2)?
[tex]\frac{\2<br /> <br /> (M(R^5-r^5))}{5(R^3-r^3)}[/tex]
I think we need to see your work. Do you know how to LaTeX your posts?
That's correct.
It is not the same thing as subtracting I of large sphere from I of smaller one, different than (2/5)M(R^2-r^2)?
Not exactly. If you treat the hole as a sphere of negative mass, then you can subtract the rotational inertia of each sphere: [itex]I_{shell} = I_{R-sphere} - I_{r-sphere}[/itex]. But realize that the mass of each sphere is different. If you express this answer in terms of the mass of the shell instead of the mass of either sphere, then you will find that you get the same answer as above.
Good catch, Doc Al. He is saying that the M in the I = 2/5 MR^2 is not the same for the sphere as it is for the inner core. So you would have to provide unique labels for each.
Do you mean making my equations in "pretty print"? Please show me where I can learn to do this, its so much easier to read!
As a check, let the shell thickness approach zero to get the MI of a thin shell.
[tex]\Delta R^5/\Delta R^3=5R^4/3R^2=(5/3)R^2[/tex]
This is multiplied by [itex](2/5)M[/itex]. The result is the correct answer of
[tex](2/3)MR^2[/tex].
? Does R man radius in or out?
Doesn't the other radius come into the equation?
Sorry for the shorthand. [itex]\Delta[/itex] means the difference between the case with R and the case with r. So for example by [itex]\Delta R^5[/itex] means [itex]R^5-r^5[/itex].
