What Is the Symmetry Group of the Equation \( x^4 + a^2 = 0 \)?
zetafunction
my question is , given the Group G of symmetries for the equation
x^{4} + a^{2}=0
for some 'a' Real valued i see this equation is invariant under the changes
x \rightarrow -x
x \rightarrow ix
x \rightarrow -ix
x \rightarrow -x
x \rightarrow i^{1/2}x
x \rightarrow (-i)^{1/2}x
under this symmetries we can see that we ONLY can have imaginary roots, since from the symmetries above any complex number solution to x^{4} + a^{2}=0 should have an argument 4\phi = 2\pi this is deduced from the base that x^{4} + a^{2} is a real function for real 'x' , of course this example is TRIVIAL to prove to be true , but how about a more important case, could we deduce from my idea that ALL the roots of the function x^{-1}sinh(x)=0 are ALL imaginary numbers ?
given any Polynomial K(x) with the following properties
* K(x) have ONLY pure imaginary roots (A)
* degre of K(x) is a multiple of '4' (B)
could we proof by any REDUCIBILITY theorem (over Real numbers) that the irreducible factors of K(x) over the field R are or will be of the form (the best possible chance) x^{4} + (a_i)^{2} for some a_i ??
Another question is are conditions (A) and (B) equivalent ??
A few places where you're not quite right:
1) This equation is not invariant under the transformations x \mapsto \pm i^{ \frac{1}{2} } x since ( \pm i^{\frac{1}{2}} x )^4 = i^2 x^4 = -x, not x.
2) Do you mean that x^4 + a^2 = 0 as only pure imaginary roots? Because that's not true for a = 2, so your two *-ed conditions are certainly not equivalent.
3) No, even under those assumptions the irreducible factors do not have to be of that form. Consider for example (x-i)^4, or if you want one that doesn't split, (x^2 + 1)^2.
