How Much Underground Pipe is Needed to Cool Water from 70°F to 60°F?
  • Thread starter Thread starter kjsigpa
    Piping
To cool water from 70°F to 60°F using buried polyethylene pipe, the amount of pipe required depends on factors like flow rate and ground temperature. The average underground temperature is noted to be around 53°F, which influences heat transfer calculations. While specific formulas for heat transfer and capacity are necessary for precise calculations, initial estimates can be made by assuming constant ground temperature. Resources like ground source heat pump guidelines can provide useful rules of thumb for these calculations. Accurate results will require thorough analysis of heat transfer dynamics.
kjsigpa
Hello everyone, I appreciate any help you can provide me in this project.
Here is what I need to know...
How much pipe (probably some form of poly ethelene) do I need to bury to reduce the temperature of the water inside?
My input temperature should be about 70. Output desired is 60 or so. One inch pipe. Five gallons per minute flow rate. Average underground temperature is about 53.
I need to be able to show the calculations so please show me the formulas and what the variables mean.
Thanks for your time,
Jay
This problem is pretty difficult because it involves accounting for the heat capacity and heat transfer capability of the ground. Except maybe for some rules of thumb on ground source heat pump loops (google for it), it probably doesn't have an easy answer.
Thanks Russ,
I am going to have to get through the calculations. Can you help?
Jay
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
