Water bubble inside a microchannel
  • Thread starter Thread starter Excom
    Bubble Water
To calculate the force needed to move a water bubble inside a microchannel, one must consider the pressure difference created by increasing air pressure on one side of the bubble. The relevant forces involve wetting, where the air/water/glass contact line must move for the bubble to shift. Young's equation can be applied to estimate the force required to overcome the interfacial energies, assuming a contact angle of 90 degrees for simplification. The derived pressure difference necessary to initiate bubble movement is 140/r dyn/cm², indicating that as the channel size decreases, a larger pressure difference is required. Experimental measurement is encouraged to validate this theoretical approach.
Excom
Hi
I need to calculate the force needed to move a water bubble inside a microchannel. Initially, the bubble is at rest and then the air pressure is increased on one side of the bubble.
I am new in microfluidic and need some help about where to start in order to solve this problem.
Thanks
hi
i didn't understand for you
can you tall us whether more,please
thanks
I have a water bubble inside at microchannel. There is air on both sides of the bubble. I then increase the air pressure on one side of the bubble. The air pressure on the other sides is not changed. How much do I have to increase the pressure before the bubble starts to move?
This is a great question! I'm not sure I have an answer, but let's see..
What are forces involved? We can ignore gravity. So it's really wetting: the air/water/glass common line must move in order for the bubble to move. Now, wetting is not understood and there are a lot of microscopic models that have been proposed, but macroscopically, we can maybe estimate:
Young's equation relates the contact angle and interfacial energies. To make the text here easier, let's assume the contact angle is 90 degrees (It's not, but you can work this out later). The air-water interfacial energy is 70 dyn/cm, so multiply this by the circumference of the bubble and you have a certain force to overcome in order to move the contact line. Now, if the glass surface is dirty or otherwise rough all bets are off, but for now, let's just consider the surface to be clean, flat, chemically homogeneous, etc. And I've neglected the air-glass and water-glass interfacial energies.
Then the required pressure difference will be 2*70*2*pi*r/(2*pi*r^2)= 140/r dyn/cm^2. As the channel size goes down, r decreases, requiring a larger pressure difference- that agrees with reality, at least.
It's fairly easy to measure- try it out and see how well it agrees, I'm curious.
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
