Sin Wave Generator IC: Find Availability in Your Country
Users are seeking recommendations for sine wave generator ICs, emphasizing the challenge of availability in different countries. Function generator ICs are highlighted for their ability to produce sine, triangle, and square waves at a low cost. A Google search link is provided for further exploration of options. The discussion underscores the importance of finding accessible components for signal generation. Availability remains a key concern for users looking to implement these ICs in their projects.
oufa
can anyone please give me aname of sin wave generator IC .but many ICS as you know as it might be not available in my country
The key term to use on Google is "function generator IC". The ICs that are used in benchtop signal generators can make very nice sine, tri and square waves, and are relatively inexpensive. Here's the Google hit list:
http://www.google.com/search?source...=1T4GGLL_enUS301US302&q=function+generator+ic
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
