Maximum Force - Linear momentum
To determine the maximum force F0 acting on a 2 kg box, the problem involves analyzing the force over time as the box accelerates from rest to a velocity of 5 m/s at t = 8 s. The equation of motion, mv1 + ∫F dt = mv2, is applied, with initial velocity v1 set to zero. The integral of the force from 0 to 8 seconds is calculated to find the total impulse imparted to the box. The user seeks confirmation on their approach to integrating the force to solve for F0. Clarification on the integration process and the correct application of the equations is requested.
skp123
Assuming that the force F acting on a 2 kg box, as it passes
horizontally through a channel (see Fig. a), varies with time
in the manner shown in Fig. b, determine the maximum
force F0, applied to the box. The velocity of the box reaches
5 m/s when t = 8 s. Assume that the box is at rest at t = 0.
Neglect friction between the wall of the channel and the
box.
http://img715.imageshack.us/img715/1446/37196096.jpg
mv1 + sum integral F = mv2 - sorry for writting integral with words
So this is how i proceed.
At the beginning v1=0. No velocity
in x direction
m*0 + integral from 0 to 8 Fx = 2*5
Now we integrate and find the force. But i am not sure if this is the right way to do it.
Can anybody help me a little bit
Plese people. I need a little help.
