Charge on 1cm Wire: Solve with E=Q/4πεor^2
  • Thread starter Thread starter Zywo
    Charge Wire
The discussion revolves around calculating the charge on a 1.0-cm-long segment of a charged wire, given the electric field strength at a specific distance. The initial attempt used an incorrect formula for the electric field, leading to confusion. The correct approach involves using the charge density (lambda) to derive the electric field equation in terms of distance from the wire. The final formula provided is E = 2(lambda)/(4*pi*eo*r), where lambda represents charge per unit length. This clarification helps guide the user toward the correct method for solving the problem.
Zywo
The electric field 4.80 cm from a very long charged wire is ( 2100 N/C,toward the wire).
What is the charge (in nC) on a 1.0-cm-long segment of the wire?
E=1/(4*pi*eo) * Q/ri^2 * cos (theta)
3. The Attempt at a Solution
I put in 9*10^9 for 1/(4*pi*eo)
I put in (.048^2+.01^2) for ri^2 and for cos theta i put .01/4.8
I thought this equation would have worked with the old plug and chug method, is this the right equation for this situation?
Thanks
No, that's not correct. Think about what the equation means and you'll see why.
To start off, assume that the line of charge has a charge density of lambda and use that to find an equation giving the electric field in terms of r. Then plug and chug into THAT equation.
Ah. 2(lambda)/(4*pi*eo*r)
lambda = Q/L
Got it.
Thanks!
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
