How Do You Create a Sub-Matrix Based on Vector Conditions?
  • Thread starter Thread starter Saladsamurai
    Logic Program
The discussion revolves around extracting a sub-matrix R from a larger square matrix M based on the values in a column vector C. The entries in C determine which rows and columns of M to keep, where a value of 0 in C indicates that the corresponding row and column should be excluded. The goal is to implement a method to populate R with the remaining entries from M after crossing out the specified rows and columns.The proposed solution involves using nested loops to iterate through the indices of M. If the corresponding entry in C is 1, the code assigns the value from M to R, while maintaining separate counters (rx and ry) to track the position in R. There is also a clarification regarding array indexing, noting the difference between 0-based and 1-based indexing, which affects how the loops are structured. The final pseudocode reflects these adjustments to ensure correct indexing and assignment of values.
Saladsamurai
I am confusing the heck out of myself here.
This is what I have
Square matrix that is M = 'm x m'
A column vector that is C = 'm x 1'
a smaller square matrix that is R ='r x r'Here is what I am trying to accomplish; I usually do this by hand:
The entries of the column vector C are either 1 or 0. If the ithentry in C is zero then I can "cross out" the ith row AND column in M. For example, if M is 5 x 5 and the 2nd and 4th entries of C are 0, I draw a line through the 2nd and 4th row AND column of M.
This leaves me with a 3 x 3 sub-matrix that is made up of the un-crossed out entries of M.
This sub-matrix is R. So I need to find a way to assign these values to R from M after crossing out rows and columns according to the entries of C.I have already created a test to initialize a matrix R of the correct dimensions; it is now a matter of getting the entries in there.
Something like:
Code:
For i = 1 to M
    For j = 1 to M
    If C(i,1) = 1 Then {R[something,something] = M[Something,Something]
     Next j
Next i
But I think I will need 2 more counter variables in addition to i and j so that if C(i,1)=0 the indices of R do not increment.
I am just a little lost now. Can I get a little help here? :smile:
Technology news on Phys.org
I would do something along the lines of:
(Pseudocode)
Code:
rx = 0
ry = 0
for(mx = 1 to M) {
    if(C[mx] == 1) {
        ry = 0
        for(my = 1 to M) {
            if(C[my] == 1) {
                R[rx][ry] = M[mx][my]
                ry++
        rx++
DaveE
(Pseudocode)
Code:
rx = 0
ry = 0
for(mx = 1 to M) {
    [B]if(C[mx] == 1) {
        ry = 0[/B]
        for(my = 1 to M) {
            if(C[my] == 1) {
                ry++
        rx++
DaveE
Hey there Dave :smile: I am kind of bad at this...what is the part on bold doing?
It's saying if the value at C[mx] (the mxth value in the single-dimensional matrix C) is equal to 1, then execute the code that's in the following set of braces. The first line in that sub-block of code says to set ry equal to 0.
I should note that actually, there's a little confusion there in terms of indexing. If your arrays are 0-based, then you want:
Code:
rx = 0
ry = 0
for(mx = 0 to M-1) {
    if(C[mx] == 1) {
        ry = 0
        for(my = 0 to M-1) {
            if(C[my] == 1) {
                ry++
        rx++
And if your arrays are 1-based, then you want:
Code:
rx = 1
ry = 1
for(mx = 1 to M) {
    if(C[mx] == 1) {
        ry = 1
        for(my = 1 to M) {
            if(C[my] == 1) {
                ry++
        rx++
DaveE
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
