Weinberg: The Quantum Theory of Fields I, Eq. 2.5.14
Living_Dog
First off I am a physics instructor at a local school and am trying to learn QFT from books. So this is not homework for a class at all.
I am trying to re-derive Eq. 2.5.14 from the above equation to it and it is in fact that "above" equation which is my hurdle. It is on pg. 66 for those of you with the book. Here is some previous information (for those of you without it) which I have struggled with the passed few days (actually weeks but I only get to spend a few hours each week due to other activities):
page 63:
momentum operator: P^\mu \Psi_{p,\sigma} = p^\mu \Psi_{p,\sigma} (2.5.1)
unitary operator of a boost on a single particle state: U(\Lambda)\Psi_{p,\sigma} = \Sigma_{\sigma '} C_{\sigma'\sigma}(\Lambda,p) \Psi_{\Lambda p,\sigma} (2.5.3)
"In general, it may be possible by using suitable linear combinations of the \Psi_{p,\sigma} to choose the \sigma labels in such a way that the matrix C_{\sigma'\sigma}(\Lambda,p) is block-diagonal; ..."
page 63-64:
"Our task now is to work out the structure of the coefficients C_{\sigma ', \sigma}(\Lambda,p) in irreducible representations of the inhomogeneous Lorentz group."
He defines a standard 4-momentum, k^\mu, which is invariant under a subgroup, W, of the homogeneous Lorentz group, L. So W \subset L, and is used to boost k^\mu to an arbitrary 4-momentum p^\mu via:
p^\mu = {L^{\mu}}_{\nu}(p) k^\nu.​
Note: L(p) \in W
single particle state of momentum 'p' defined:
\Psi_{p,\sigma} \equiv N(p) U(L(p))\Psi_{k,\sigma}.​
Therefore:
U(\Lambda) \Psi_{p,\sigma} = N(p) U(\Lambda) U(L(p)) \Psi_{k,\sigma}.​
Using the multiplication rule for these unitary operators: U(A)*U(B) = U(A*B), then:
U(\Lambda) \Psi_{p,\sigma} = N(p) U(\Lambda L(p)) \Psi_{k,\sigma}.​
Inserting a factor of 1 = U(L(\Lambda p)L^{-1}(\Lambda p)) then the above becomes, after applying the multiplication rule:
U(\Lambda) \Psi_{p,\sigma} = N(p) U(L(\Lambda p)L^{-1}(\Lambda p)) U(\Lambda L(p)) \Psi_{k,\sigma} = N(p) U(L(\Lambda p)) U(L^{-1}(\Lambda p))\Lambda L(p)) \Psi_{k,\sigma}.​
The second unitary factor takes k to p then to \Lambda p and then back to k. This forms the little group, W, of the homogeneous Lorentz group - it keeps k the same. Namely, k^\mu = {W^{\mu}}_{\nu} k^\nu and
W \equiv L^{-1}(\Lambda p)\Lambda L(p). (2.5.10)​
Note: I think that the standard 4-momentum is just another way of saying the 4-momentum in the particle's in its rest frame.
For any such W:
U(W)\Psi_{k,\sigma} = \Sigma_{\sigma'} D_{\sigma'\sigma}(W)\Psi_{k,\sigma'} (2.5.8)​
The irreducible matrices D_{\sigma'\sigma}(W) satisfy the following relationship:
D_{\sigma'\sigma}(\overline{W}W) = \Sigma_{\sigma''}D_{\sigma'\sigma''}(\overline{W})D_{\sigma''\sigma}(W) (2.5.9)​
Note: we may chose the states with standard 4-momentum to be orthonormal, i.e.:
<\Psi_{k',\sigma'}|\Psi_{k,\sigma}> = \delta^3(k'-k)\delta_{\sigma'\sigma}​
The next step, to determine the normalization factor, N(p), Weinberg starts from the bra-ket of two distinct single particle states, namely:
<\Psi_{p',\sigma'}|\Psi_{p,\sigma}> = N(p)<U^{-1}(L(p))\Psi_{p',\sigma'}|\Psi_{k,\sigma}>​
and obtains:
= N(p)N^*(p'){D^*}_{\sigma\sigma'}(W(L^{-1}(p),p'))\delta^3(k'-k).​
This is the equation which I cannot derive. How does one go from the next to last to this last equation?
-joe
____________________________________
and obtains:
It is useful to note that the product <\Psi_{p',\sigma'}|\Psi_{p,\sigma}> is non-zero only if p=p'. So, I will replace p' \to p and k' \to k where convenient. Then
<\Psi_{p',\sigma'}|\Psi_{p,\sigma}> = N(p)<\Psi_{p',\sigma'}|U(L(p))\Psi_{k,\sigma}> = N(p)<U^{-1}(L(p))\Psi_{p',\sigma'}|\Psi_{k,\sigma}> = N(p)<U^{-1}(L(p))\Psi_{p,\sigma'}|\Psi_{k,\sigma}>
= N(p)N^*(p) < U^{-1}(L(p))U(L(p))\Psi_{k',\sigma'}|\Psi_{k,\sigma}> = N(p)N^*(p) < \Psi_{k',\sigma'}|\Psi_{k,\sigma}> = |N(p)|^2 \delta_{\sigma, \sigma'} \delta(\mathbf{k-k'})
Eugene
Eugene
Holy mackeral! I didn't see the forest for the trees! I kept seeing:
U^{-1}(L(p))U(L(p))​
as
U^{-1}(L(p))U(L(p')).​
because he applies p = p', after this result, at the end. So I was stuck thinking that it is only applied at the end. I never thought to apply it ahead of that. (such a dope! - I am...)
Thanks ever so much, now I can make some more progress.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
