Space and Time Invariance (Classical Wave Equation)
The discussion centers on the invariance of the classical wave equation, specifically comparing the second-order wave equation, which is space and time invariant, to the first-order equation, which is not. The second-order equation, ∂²y/∂t² = v² ∂²y/∂x², maintains its form under transformations, indicating invariance. In contrast, the first-order equation, ∂y/∂t = -v ∂y/∂x, does not preserve its structure, demonstrating a lack of invariance. Participants suggest testing a simple wave function, y(x,t) = sin(x+vt), in both equations to illustrate the differences in behavior. Understanding these distinctions is crucial for grasping the fundamental principles of wave mechanics.
mess1n
Hey, I've come across a part in my notes which I can't figure out. Essentially it says:
\frac{\partial^{2}y}{\partial t^{2}} = v^{2} . \frac{\partial^{2}y}{\partial x^{2}} is space and time invariant.
Whereas:
\frac{\partial y}{\partial t} = -v . \frac{\partial y}{\partial x} is not.
Why is this the case?
Cheers,
Andrew
Try putting a simple wave like y(x,t) = sin(x+vt) into both equations and see what happens.
Guessing at equations is a standard way for physicists to explore a problem.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
